sakroda
- 233
- 36
- May 3, 2016
İstanbul,
Europe
Hello
I am renewing my car but still ı couldn t figure out stopping engine
When i press full throttle gas pedal and when i move my foot from gas pedal talon is stopping or when i turn the steering wheel it s also stopping i renewed the vacuum hoses but no luck
when i check the vacuum line i saw purge control selenoid valve removed that s why i had to connect hoses to throttle body direct..I don t have idle position switch i ordered last week then i will try it
Do you have any idea why it s stopping when car is warmed? I changed the o-ring of ISC but it s the same..
last question it makes me sick when you engage the gear to 2th and Car's speed is going down slowy after then talon is shaking so rougly i understand it needs gas or engage the small gear but it s too much shaking. is that normal? By the way clutch kit is renewed also
thanks..
when i check the vacuum line i saw purge control selenoid valve removed that s why i had to connect hoses to throttle body direct..I don t have idle position switch i ordered last week then i will try itDo you have any idea why it s stopping when car is warmed? I changed the o-ring of ISC but it s the same..
thanks..
