My DSM questions.
bigbird94
264
7
Jun 22, 2011
Fond du Lac, Wisconsin
Hello, I am new to posting on this site but having been reading the tech articles and working on my cars for years now. I recently acquired a 1992 Talon TSI AWD auto with 80k miles. The first day I had the car it started smoking and died. After reconnecting a starter wire that wiggled off when it died I got it to start. It was making loud knock, I instantly shut it off and began to pull the engine. With the engine out I diagnosed a failed oil pump/ balance shaft. I am ready to do an engine freshening and need advice. Here is what I have planned so far.....
-New OEM oil pump
-DSM graveyard B/S delete
-Full fel pro gasket kit
-New OEM timing kit
-Anything else while im in there?
The car already had arp head studs and an 85.5mm Cometic metal head gasket. The head looks like it has minor imperfections. I plan on cleaning the engine block with chemicals and get it as clean as possible. My worry is the head. Should I suck it up and pay to get it disassembled, decked, and rebuilt. Or can is there a solid DIY method to clean it up. I of course plan to check valve clearences and flatness on both the head and deck. I should also add that I plan to use the composite fel pro head gasket.
Sorry if this is the wrong section or too lengthy.
Thanks for reading.
Any help would be appreciated.
I would take the head to a machine shop and get it re-surfaced and also change the water pump while your in their with a oem unit.
I agree with Pauly.
Not sure what your plans are with the car, personally i would get the head port/polished and valve angles reworked, wouldn't hurt to replace the valve stem seals and taking a look at the valve guides for wear. Just my 2c
edit: also consider some new 3g lifters (if u need them)
I want to run the car with regrind 272s and a 14b with jackal speed density and learn to tune then go to a holset hx35 and 1000cc injectors etc down the road. If I do get the head rebuilt it will be with all new valves, seats, 3g lifters, and a mild port, I just want it on the road for the rest of the season without breaking the bank.
I used non oem water pump for OVER 15 years no problems, oem belt now before other brands never problems. Also there are timing belt kits out there for a good price everything you need. The good thing is one the mainteance is done your good to go.
