My log..Someone look please?
MrToniFliTSI
31
Oct 18, 2002
Depew,
I am new to logging. Today I had less than a quarter tank of gas in my car. Here is the log
It was cold this morning. THis is at Idle
RPM-1812---------------
INJP-4.09ms
KNOCK-43
02-R0.58v
02-F2.85v
TPS-19.1%
INJD-5.4%
TIMA-15 Degrees
COOL-42.5degrees
airT 8.5 degrees
BARO-0.96
EGRT- -28.2 degrees C
ISC 27.7%
FTRL 114%
FTRM96%
FTRH 95.3%
FTO2 100.7%
MAFS 169.8Hz
Can you tell me what is bad amd what is good and how to correct the bad? I know the knowck is high. After I got gas the knock count was no higher than 5. Would that be a culprit for high knock?
I think your a little confused about logging.
Sitting in your driveway isn't the way to do it.
Go out and do a 3rd ger pull from say 3k up to 7k and then look at your results.
Come back with that info and then we can tell you what is good or bad about it :thumb:
RPM-2281 The highest I have so far until I get another pull. While driving
INJP-5.37ms
KNOCK-43
02-R0.78v
02-F2.85v
TPS-25.7%
INJD-10.1%
TIMA-11 Degrees
COOL-45.2degrees
airT 11.1 degrees
BARO-0.96
ISC 27.7%
FTRL 114%
FTRM96%
FTRH 95.3%
FTO2 101.5%
MAFS 314.4Hz
When I log my car I don't log all of those things. The 4 things I would moniter when logging are timing, throttle, o2's, and knock. You need to do a 3rd gear pull like Canadian tsi said from around 3k to 7k. It is possible you can get knock from bad gas, but if you got 43counts of knock at idle you are probably getting some kind of phantom knock. I really need to see a 3rd gear log to tell you.
