my key wont open my trunk -_-
xXEclipse
470
Aug 30, 2010
Montrose, California
ok so idk if my key is a valet key cause it locks/unlocks the glove...
also its opened the trunk before ONCE.
does anyone know whats going on...
also whats up with two step trunk release -_- sometimes it works in one shot sometimes it doesnt.. can someone clarify
Sent from my DROID2 using Tapatalk
i dont have any others its the key the guy who i bought it from gave it me
also.. sometimes the trunk release requires one pull other times two pulls
Try pulling out the lock cylinder and taking a look at the wafers. You'll understand once it's in your hands.
I had the same problem, I fixed it by adjusting the latch inside the trunk. You need to remove the center panel inside the trunk, and you will see that the latch has 2 bolts that holds it in place. Loosen them a little and adjust up/down until the hatch releases in one turn of the key.
Mine does the same thing. I think its the tumblers inside that are wore out. I have two keys and both of them don't work. Sometimes if Imess with it for a couple minutes it will open but I'd rather just pull the release.
