my first big build
Lil' Shaun
210
Nov 30, 2003
dayton, Ohio
I have been building my 1G off and on for the past 3 years. I just wandered what you all think of what i have so far.
balance shafts removed
balanced crank
eagle H-beam rods
weisco 8.7:1 pistons
aluminum flywheel
aluminum aem pulley set
aluminum ebay crank pulley
.025 milled head
ported and polished head (polished in a tumbler)
supertech 1mm oversize stainless valves
brian crower springs and titanium retainers
brian crower 280 cams
HKS cam gears
HKS timing belt
cyclone intake with butterflys removed ported and polished (polished in a tumbler)
turbonetics T3/T4 turbo
HKS catless 3" downpipe
megan 3' catback
arp head studs and main studs
also wonderd about how much power I will make at 25-30psi
What turbo EXACTLY are you going with? Turbonetics T3/T4 can be soooooo many
Make sure to get the entire bottom end balanced all together, not just the crank
Id stick with OEM Crank Pulley and trash the ebay one along with AEM pulley
280 Cams seems a bit much, but then again it depends on what turbo your planning on using, rev limit, etc.. etc.. and i'd get something better than BC
Be clear on what your looking to do, like horsepower, maybe times, and goals... that way people can help you better with your "build"
