my first big problem
nasty_4g63
91
Jun 19, 2012
Lancaster, Pennsylvania
So i was driving my car home from work today and when i got off the highway my idle just started to act up it shot straight up to 4k so I shut the car off waited a few mins and turned it back on it would barely idle it would just miss fire and run like crap. When driving it isn't that bad other then when I push in the clutch to shift the rpms jump up like crazy. It is also running very rich. I feel like it is my iac but would that cause he weird miss fire at low rpms or even a vacuum leak.
my gst used to do this and it still kinda does on first morning start up. take out the idle air control sensor and clean it with break parts cleaner and put it back in do the same to the tps i cured a lot of my problems and i got better throttle response.
