My 92 build and a little history
Well i didnt make quartly bonus :( , but still got V3, rewired the fuel pump. Ordered 3q Redline MT-90, 2q heavy shock, water wetter, NHRA JEGs rear battery box and master disconnect switch..still need exhaust :(
forgot I had some picts on my bucket
the rewire
Those push on spade terminals are not good for high current and I've seen quite a few burn up on fuel pumps and rad fans. Use a relay socket instead, and I like to put the relay behind the plastic panel on the drivers side to protect the wiring.
Or not, I dont like any of the sockets Ive seen or I should say the wires on the sockets. Running 14ga to 16ga and 16ga to 10ga doesnt make much sence. Ill just cut off the yellow plastic
Your build looks great! One thing I noticed when looking through the pictures was that the timing belt was not tensioned properly. The tensioner pulley is clocked the wrong way. The holes should be lined up at about 10 and 2 o'clock. Next, look at how far out the hydraulic tensioner pin is sticking up. With a new belt that has been properly tensioned you should be able to pull the pin and put it right back in. I would go back and fix that before running it. Everything else is looking good! Sucks about the shaft play though... Keep up the hard work.
Nice catch on the pully..thanks :ohdamn: the shaft play went away when I ran oil through the bearings guess its called floating the bearings. That timing belt had been nagging in the back of my mind
Yay Jegs
freshing up the front cowl and wipers
yup still trudging along :p
gawd I hate wiring
But they came out nice
relocated the over flow
Put the battery back in the bay :ohdamn:
02 bung...Thanks Trev Tec
If the exhaust bolts hadent been to short I could have started it, but thats next week project. So whats left?? Catback, insurance, title and registration...and tune
EDIT...shep clutch pedal is a PITA
So after a week of reading NO START threads, I ended up pulling the starter to have it tested. The guy comes back and say "yeah man its good", "I say are you sure" hes "yay passed three times". I was hoping this was the problem :(
So me and a Friend Chris, break out the multimeter, pull the ECU, MPI relay somethings not testing right on the relay at this point the dash is almost pulled out. Come to find out one of the clutch pedal safty switches had a jumped on it, beats me never buy an PO project car. after 3 hours.
and this.
next week base settings and start up:pray:
Its alive clicky
moving on it own power....now I dont feel like the owner of Christine
just a front shot
Got lucky at the Pick a Part
and a clean bumper cover
my Buddy Chris and my boy
Your build project looks fantastic. You have done a really great job getting all your stuff fabbed up and getting your own work done.
I can't wait to see the final result and see some numbers from it.
Thanks...last leak is the oil preasure relief valve :notgood: tried 3 ways to get it to seal so far, then moving permit and the exhaust fitted and the car registered
wow car has came a long way. the car looks great. cant wait to see some numbers from her!
Getting...DONE... exhaust tomorrow, then title and register
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
