my 2g gs-t build
95weclipse
307
3
Jun 26, 2009
LaSalle, Illinois
ok so i am starting my 2g build
i got the car for 500 with a broken connecting rod bolt broke and the piston started to hit the cylinder head but they shut it off right after words...
so where i am at now
i got the motor completely torn apart down to bear block i have the balance shaft bearings turned(not buying an eliminator kit just make my own)
i have two exhaust ports on the cylinder head ported out and polished... i also have two ports on the manifold ported in as far as i can get and polished...( air compressor took a shit today)
i am going to run a 14b turbo, with j pipe and greddy hard pipe inter cooler.... for now going to run the stock side mount... the turbo is ported and polished all i have to do is grind behind the waste gate flapper hinge so it can open up all the way
i have stock injectors(there brand new)
i want to run a 1g throttle body
i have one cylinder honed so far today
i think i am going to buy new valves i dont know :banghead:yet:banghead:
i am gonna get 272 delta regrinds
i have a stainless steel 3in exhaust with the flow thru cat and full flow thru cat back exhaust just need a down pipe
i am getting a rebuild kit saturday
um if i can think of any thing else ill post it
ill have pics up of the engine soon i only have ones of the car:rocks:
so i need a crank or i dont know if i get get this one cut or not its pretty bad and the thrust area has a slight gouge on one side
i started honing the rest of the cylinders today so far i cant do much else with out my air compressor(engine wise any way)
so i started to put the exhaust on i only got the muffler on which is a bi*** because you have to raise the ass end super high and take the tire off to get the right angle so that on and up on the car
i am going to remove the shifter today and when i get access to a welder ill cut it down and weld it up.
i still need to get to the junk yard and look for a 1g throttle body
if your looking for exterior mods for your 2g I sell vertical door
kits. direct bolt on hinge kits for 1095 plus shipping
so i think i might just buy another block but i am waiting on the shipping price so if it ant to bad then ill get it ### its bored .20 over but my block will work
so i havent gotten the air compressor fixed yet but i got pics i am posting them now check them out
well i need to find a crank still and i have the cylinders honed and ready for the rebuild now what iam waiting on is my rebuild kit when that gets here i have to have the pistons switched out and then i got to replace the rod bolts with arp hardware and i am going to get this beast back on track
hey i was chcking out your post and you said you were not going to buy a balance shaft eliminator kit and you were gonna make your own and i was wondering how do you do that??
