My $20-30 vacuum bleeding canister
Today I went to Lowe's to buy stuff to build a canister to vacuum bleeding. I have bought 2 of the hand pumps with the tiny cheapo canisters in the past and with both sets the canister rotted the o-ring after 1 use and both pumps had the check valve wear out.
What I bought:
- 3" PVC coupler
- 2x 3" cleanout adaptors
- 3" cleanout plug (square nub on the end)
- 3" plug (flat)
- 2x NPT to hose barbs
- 20 feet of hose
- PVC glue
Stuff I already had:
- PVC primer
- Teflon tape
- Vacuum gauge
Assembly is self explainatory. I glued the flat/bottom plug in because it never needs to come out. This project cost me $26.91. I just use the engine's vacuum as a source. It's free, except the gas used to idle the car. The canister probably has more than a quart of capacity. The most difficult part of assembly is putting the barb fittings in. I have NPT taps but PVC will allow the fittings to self-tap and seal perfectly so I just always use a slightly smaller drill bit and force thread the fittings in place. The hose barb and vacuum gauge threads don't need teflon tape. I put teflon tape on the cap threads, too. I tested how it hold vacuum and it went down only a 2 or 3 inHg in 30 seconds. This was just pinching the hose and having my finger on the other barb.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
