My 1g is running terribly rich
Jpaulson64
Mar 27, 2012
Erie, Pennsylvania
I recently installed a 16g, ewg, 450cc injectors, 2g maf and a crushed 1g bov and a 90 manual eprom ecu with link v3 lite on my 91 talon auto trans. Ive been driving the car for 2 weeks and im getting terrible gas milage and when i left off the throttle at low speeds/ crusing speeds the car will bog dowm and sometimes stall. Ive checked for boost leaks and have none ive been doing research and people are saying to rescale the 2g maf but im not sure thats the problem just trying to get some more opinions on ### my problem is???
Is your BOV recirculating?
Do you have a wideband?
Have you checked your spark plugs, or are you just assuming its running rich?
If you have link make a log and post it up, this will tell us more than words can.
My bov is recirculated and as far as i know my injectors r setup idk how to tune for the maf though i also have a wideband i just havent hooked it up yet but ill try and post a log up soon
:ohdamn: If you don't have a tuning device set up properly then you can't just slap a 2g maf on the car.
Well thats kinda my problem..idk how to set it up for a 2g maf so im probably going to run the 1g maf until i get my aem wideband hooked up ill get u guys a log soon thanks for the support guys
Don't know if lite has it, but v3 full has the base 2g MAF settings on it. And there's a video on how to use the maf compensation feature to dial in your maf.
Could always post up a log and let ppl see what is going on. I'd go back and watch the video's on the ecm's website.
