my 05' performance setup
Thomas91169
4,490
28
Jan 18, 2004
modesto, California
Evo16g Ported/34mm flapper mod from ExtremePSI - 620
2g install kit with SS braided line and 1g oil drain tube - 200
190lph pump - 95
550cc injectors - 280
SAFC2(black) ebay - 265
mods already installed(or have)
Pocketlogger software
ACT2100 clutch kit
K&N filter/adapter
Greddy Hard IC Piping
3" custom catback with Apexi N1 OBX ripoff
Tubular 02 Housing from Punishment Racing
Dejon Tool dual stage MBC(low 11, high 20)
im hoping to break into 13's with crappy driver. :rolleyes: how do you all like the new setup? i figured since ive had her from a year this january its time to make her feel new again.
Good choices on the setup...Looks like you did your research and found some good prices on the parts :thumb: 13's sounds realistic with some good tuning but just remember that you are still FWD so the launches will be a PITA. That and you being a spyder are your really only disadvantages. Still, there's a few EvoIII powered spyders running 13's on the 1/4 times list here so you should be fine...
-btw, after upgrading all those parts, just remember to save some $$$ left for when a different part brakes
nah, unless im at the track or actually see someone worthy for full boost on the streets, i usually baby my baby and never even see 5psi.
but after this goes in i might save for a shepracing tranny rebuild with either a quaife or kaaz lsd.
or i might just say fwd spyder is done, moving on to awd 1g beast"
it would help to lower the chance of knock, but i dont really see full boost much and dont really race people in the heat of day, if i do race its late at night when its cooler and nobody on the road.
but theres a small chance i would be able to get a fmic by the summer, i might get the OBX kit, seeing as its an apexi core(or equal)that flows and cools the same. i would be the guinea pig.
rightaway said:
i would go a little bigger than 550 because i ran out of fuel with my 550 on the evo16g at 18-20 psi.
Umm what fuel pump did you have by chance? i have the same setup and on 550s i run 20psi Hard also i dont have any fuel problems.
I've been 13.6/13.7 half a dozen times on a fwd 2g, no fmic, evo3 16g, stock suspension, bushings and motor mounts, street tires with some fairly crappy driving.
I'm sure you'll hit a 13.xx with some tuning and practice.
-T
