MTX-L keeps reseting
TAMA_player
141
13
Jan 27, 2007
Aguascalientes, Central America
So, today my MTX-L start to have this issue.
It just keep starting up over and over.
I tried to change ground, and 12v power. Also changed a spare o2 sensor.
Disconnecting the sensor is the only way to have an error code (e2), but every time i connect the sensor it starts with this issue again.
Any help will be really a appreciated
Where are you taking your switched power from? They really do need and like there own supply otherwise they throw a fit. try taking it from the harness from your key barrel and having its own power with a 5a fuse inline. This worked for mine ever since changing or go with a motorsport fuse power block that give you a few independent power supplys from 1 feed, this is now my new route for multiple gauges
I have a separated direct to battery line for my progressive alky controller and for the wb.
I tried also to connect directly to battery.
Edit: Today i replaced power lines, and in the process the positive cable just breaks, so seems that the issue was a bad power cable.
Oh corrosion in the line would be a good reason for it to do that, glad you sorted the issue.
Oh my bad then,
  • Wanted 6 bolt NT water pipe
    • chrisman287
