mounting coil pack...
greathuskie
2,666
4
Sep 10, 2002
Hollywood, Florida
i cant find where stock coil pack is mounted, i think it was over the motor mount, but is there any way i can moiunt mine on the block somewhere? right now its tucked into the IM but the thundervolt wires are pretty long. any clever ideas or pics where i can mount it?
Check my avatar. I have the thunder volt also and I did not need to buy anything , I just re-use the stock bracket, modified a little and mount it on the strut tower.
how did you modify it? i like it and it would help my car out quite a bit.
Just drilled the hole on the bracket where the bolt is, so it will fit on the strut bolt. bended upwards . I'll try to send you some pixs. Here is a link I hope it helps you.:D
