motor parts help!!!
4g63turbo84
614
Dec 10, 2008
ocala, Florida
OK this is my situation i though i was buying a good deal on a motor, clam it was a built motor in good Sharp just had a spoon rod bearing, it was a 6 bolt motor with eagle rods, eagle crank, and wescro pistons, also some arps head, main bolts for 500$ when i got it to the shop i had them pull it apart and they said i will not be able to use the crank, pistons, and one of the rods, so as soon as i got home i found a guy selling some wecro pistons .20 over for 200$ i talked him down to 170$, and i just got them in today, they are not moving freely on the rods, only two are moving with help and the other two are not moving at all. if they are reusable i will only need one eagle rod for a 6 bolt. also about the crank i do have a stock crank that i plan on using.
