motor mounts auto 2g /how to install
Cesarlcase
261
5
Dec 29, 2009
lynbrook, New York
My motor mounts are shot to hell after the 2.4 was installed. My question is, first what company makes a/t mounts for 2g dsm/ will a manual mount work? Also, how hard is it to install? Is there a how to so i could locate all of them and see how It's done
So can I use the motor mount insert kit for MT in my AUTO?
I have all the other motor mount inserts already. Just trying to figure out if the ones from the MT kit will fit in the AT motor mount.
Anyone know?
If you are talking about the inserts that go on the stock mounts, then yes they work for auto and manual, I'm not sure about the full replacement bushings that have to be pressed in though.
The side and trans units are full replacements and they fit in nicely, the front and rear are inserts which go into your oem rubber mounts and on my auto I had to order 2 of the rear inserts as the progress kits front insert was to short and did not fit in flush!
It now works well but I would suggest buying the avid mounts
  • Wanted 6 bolt NT water pipe
    • chrisman287
