Motor Mount Install Question
They are inserts, for the front and rear is like a bolt on no need to cut or modify anything, its like adding more rubber to the stock mount. The other two are a complete replacement.
<------- late :p
Flat sides face out. If you look closely at the factory F/R mounts, you will see that they are not solid; they have slots in them- this is where the curved, raised portion of the inserts fit, thereby bracing the factory mount to add a little more rigidity. For anyone whos interested, the newer Prothane kits now feature solid fronts and rears to fully replace the factory rubber vs the inserts.
