Moroso oil pan leak issues.
You are probably just installing it wrong. You need the correct bolts with crush washers.
The turbo oil return?
Use new gasket and a tiny (I mean really little) amount of silicone on it. Don't use too much because the silicone will squeeze into the tube and pretty much block the return. Just dealt with that on my car.
If that is the setup you have, but I don't know what the Moroso pan uses.
I am using this flange for my -12 return line. Turbo Flanges & Gaskets, T6 / S400 Oil Drain Flange, RPS-T6ODF | RacePartSolutions.com
Its leaking from the little studs from the pan.
