1G Hello DSM family!!! Moroso Oil Pan
Installing a Moroso kicked out sump oil pan on my 1G and was wondering if I should use a pan gasket
  • yes, gasket
    Votes: 0 0.0%
  • No, RTV
    Votes: 3 100.0%
  • Total voters
    3
Long as the flange is good you could use a gasket with an ultra-thin layer of Gray rtv on it.
Personally I use rtv only, but that's cuz I don't like the rubber cork gaskets I've gotten, and they're usually torn out of the box.
Either one should work fine, just make sure the flange on the pan is knick-free.
Also, you double posted the thread, you should delete one.
