More TRANNY ISSUES!!!!!!!!
NJDMRTURBO
Jul 15, 2004
South, New Jersey
ok this what happened i was driving doing normal speeds of about 20mph in my car and all of a sudden i go to witch into another gear and, POOF! i cant go into gear. it wont move but when like u push in the clutch theres rattling when u push the clutch in and put it into a gear like if it were going to move. Does anyone know what this problem might be? :cry: :talon:
maybe the clutch fork came off the ball? That happened on my talon. The noise is the tob rubbing against your pressure plate or even the clutch fork hitting it. Unhook the slave cylinder from the fork and see if it has unusual play. Check the shifter cables too and make sure they are still connected.
did you check basics like fluid level? have you had any clutch/tranny problems lately?
check under your car, at the front of the tranny where the clutch fork comes out. Make sure the slave rod is pressing against it and move the fork by hand. If you can't push it towards the passenger side by hand, then good. If it's floppin' around in there, then it came off of the pivot ball.
the fluids all checked out good but the tranny was grinding latley. i think im just going to replace the whole drivetrain all together. solve all the problems
