More trnsmission issues
The Sorrow
88
Aug 5, 2010
Las Vegas, Nevada
Ok my clutch pedal has been going kind of flat lately. Its not nearly as stiff as it should be. Occasionally it even loses pressure and drops to the floor. Also i had to speed shift most of my way home cause the clutch seemingly isnt fully disengaging. I WAS thinking bad slave but it may also be the master not sending fluid. Not sure.
Sounds like a bad clutch master cylinder. Why don't you check it out.
Well, if the slave is leaking, I would fix that first. It needs to be a sealed system to work properly.
Fix your leaks, start there.
Im just going to replace the thing. Then return master if the slave fixes the problem. And also would this cause my 2nd and ONLY second to grind?
Possible light shed on the issue, Recently shifted into second after pumping the s*** out of the clutch and it went into 2nd smoothly. Im thinking SOMETHING hydraulic.
  • Wanted 6 bolt NT water pipe
    • chrisman287
