Clutch Issues
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
I have some weird issues going on with my transmission. When I pull out in first gear, the clutch is grabbing and causing the car to shudder. This is only happening when I have the clutch pedal coming back out. The car shifts into gear fine. It's when I'm letting off the clutch it's grabbing hard and shacking the car. I can feel it in my clutch foot as well. This is also happening while down shifting once again while letting off the clutch. The clutch grabs very hard and studders the car.
Note to be made- Once my foot is off the clutch and going in gear, it's fine. I don't have the issue.
My trans specs are- stock trans with act 2100 clutch kit with lightweight act flywheel machined down to correct spec
Anyone got any suggestions?
Maybe your shifter cables are bad or the bushings are worn, maybe the transmission has some internal issues.
How are your motor mounts looking? Sounds like more than one are torn.
