more steering angle?
MotoEclipse
144
Oct 11, 2010
Medford, Oregon
Hey guys I'm right in the middle of converting my car into a drift car, and I was wondering if anyone knew how to get more steering angle? I wont be messing around with the steering for awhile but I want to start planing for it now. any help is appreciated.
I can't help you directly but I recall either motoiq or speedhunters in older articles showed what some drift cars had done for increased steering angle. You could try sifting through their archives to see if you can learn anything.
I don't believe that anyone sells an OTS spindle for turning a DSM into a drift car, so I think that you should be lurking in the 240 SX forums to see if you can adapt their set-up.
As of right now my buddy and I are just ripping out the front drive shafts to play with it, I have the tranny for the swap im just waiting for the money for the driveshaft and mounts and everything. the center and rear diff are both welded.
Im testing the waters for the rear axles for my personal knowledge. But I plan on putting on putting a Ford rear end in the long run. I've always wanted a DSM drift car so Im not letting anything stop me. considering DSMs have such a stout engine.
I've talked to alot of people here locally and they were really interested to hear about a DSM drifting.
Ok thanks guys I'll check out some 240 forums
Somebody should be able to CNC/lathe up a quick steering rack gearset with some research..
