more problems with my bundle of joy
smokeyjpn221
115
Oct 27, 2008
salem, Virginia
aight so i am so confused and frustrated with my car that i can't even think straight:mad:
monday i cleaned my coil and adjusted my camshaft/crankshaft position sensor and the car fired. i went back up there today to adjust the camshaft/crankshaft position sensor and my luck IT WON'T DO ANYTHING! :mad: :cry: i am in desperate need of some help/advice.
:dsm::dsm::dsm:
Did you plug everything back in?
When you adjusted it did you use a timing light?
Usually if you advance it the whole way it will just idle very high so do that to see if your cas is damaged....(point being the car will start this way)
Other than that you gave a pretty vague description as to what's wrong so idk how much more i can assist
i don't know what exactly is wrong with it which is why it's a vague description. i did plug everything back in and no i didn't use a timing light.
did you damage your crank sensor, if that went bad the car wont start
not that i know of
