MORE 14b swap questions
zero97tsi
493
May 30, 2007
Duluth, Minnesota
First question, Will my stock boost control solenoid work to keep safe boost levels with the 14b?
More will come once I start the install I'm sure.
yea running a hose from the nipple on the jpipe to the actuator works best. I have a couple actually guys and i can have them powdercoated if yall are interested pm me.
Ummm... Im going to go ahead and try to nutshell this for my tiny mind.
So I should completely bypass the stock boost controler?
And instead just run a hose from j pipe to actuator?
How does this keep the boost at 10 psi?
As Ive said before Im a newbie to this whole boost thing and trying to learn as much as possible here.
And whats so funny about the word nipple splitpi... jees WTF
QUOTE]
1) Yes
2) Yes
3) The stock Wastegate actuator on 14b's trigger at 9 - 10 psi. So you only need an MBC if you want to go over 10 psi. This is how I am running my 16G till I get a new clutch and a better fuel pump.
Nipple is only funny if you have the humor of a 15 year old... which of course I do. ;)
1) Yes
2) Yes
amazazing. When I get my j pipe Ill got get a nipple (giggle) welded on and go that route.
btw... nipple ROFL
/immaturity
