14b questions
DARKTSI
51
Oct 15, 2007
ELSINORE, California
ok i just picked up a 14b turbo from this guy...it was missing the whole exhaust side and wastegate........he is supposed to bring me the exhaust side tommorow ..............### can i do about the actuator can i use anything of my t25...
the only thing you can use is the 02 housing.
the actuator doesn't fit from the t-25 because it has some wierd bends.
actuators can be used from a 16G. i'm not sure but i think any actuator from a td05h turbine housing turbo will work. from what i've seen they are the same.
^he speaks the truth, you should be able to find an actuator for really cheap though.
