Moisture
lucid15
527
Oct 10, 2008
Portland, Oregon
On my 95 gsx the footwells behind the seats are really wet, and in the morning there is condensation on the inside of the windshield. Any thoughts? sunroof drain clogged?
Mine does the same thing when you drive it when the roads are wet. It does it without the heater or a/c on. I have tried snaking weedeater string through the drain holes in the sunroof, but it didn't help. I have even pulled the carpet up and poured a little water down to see if it drips out the bottom somewhere.
I don't have a sunroof but my old talon had rust holes right behind the doors and you couldn't see them unless you were under the car. Caused my carpet and stuff to get wet on the floor... hope this helps
    • Sdcryan1
