white smoke/moisture/using coolant
90rexzc
Dec 31, 2006
Harrisville, Pennsylvania
This seems like the HG to me but the results of my search are making me secong guess myself. The car didn't seem to smoke to much when I started it to warm up before leaving work. But when i went back out to leave there was more smoke/steam. After seeing this I held my hand in front of the outlet for approx 30 sec. and sure enough it was all wet and black (carbon or unused fuel). I drove home and left the car run after I parked it. The smoke had disappeared and there was much less water coming out. I've been using or losing coolant for a while now but had ruled the headgasket out because of a good compression check and the lack of oil in my coolant and vice versa. Also the car had been overheating but stopped when I replaced the makeshift resevoir (catch can) with the OE bottle. The new bottle has a coolant level sensor so I know when its getting low and just add more. This happens every 2 or 3 days. Is it the head or head gasket? What else could cause this?
outlet of the muffler, and it is both. Theres a good bit of water, which contains unburnt fuel or carbon (black stuff). Sorry for the confusion.
thats what I thought but if you do some searching it seems relatively common/normal. Also the cap to my coolant resevoir is blowing off when Im driving. I thought maybe I hadnt put it on the whole way but its been off the last two times I checked after I made sure to close it tight.
I have a new cap, new fans, new tstat and a new radiator. ok I'll look up some instructions for a leakdown test. Another thing that I noticed was that the coolant was bubbling/boiling again when I stopped to check the coolant level. What could cause that to happen.
Bubbles in the overflow reservoir and/or coolant fill neck is a classic sign of HG failure. A rupture in the spacing from the water jacket to a cylinder will pressurize the coolant system but not necessarily allow transfer to the oil.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
