Mystikal_1788
- 216
- 0
- Aug 31, 2002
i was thinking was modifying the maf a bad idea- i did and i also modded the bcs and now my car runs like shiet has anyone else had probs from doing this 2 simple mods?
ok then it is not something the computer can pick up. Lets start with finding out what boost levels you are getting for messing with bcs and if you are rich or leanOriginally posted by Mystikal_1788
im showing no check engine codes either?
which ones are they. I dont know anyone who uses them so if the car ran good on them before goahead, other wise the BPR7ES`s are cheapOriginally posted by Mystikal_1788
well i bought ngk v-power ones today have not put the in - could i use those or should i go get the other ones?
ok tommorow i will do both and i will post at 11:00 pm when i get too work if your not on it's ok post when you can - and we will go from there- thanks alot i mean alot for all your help
those are the plugs that come in the v-tech cars stock they seem to be good plugs - the car ran great for a day on them
Originally posted by turboholic
-You can use a 2G MAF in a 1G, but must use some sort of AFC to richen the ratio b/c the 2G flow much more air. http://dmtalon.v8eaters.com/2gmaf.html
Originally posted by mavisky
actually i would run br7es's in stead of the bpr7es's since our cars don't seem to like platinum plugs.
so i retract my statement modify the maf=bad idea and add a new statement modify the maf= very bad idea without the supporting mods
Originally posted by LaserRST
Here is some interesting facts about the honeycomb removal and what effects it has on your engine...sounds exactly like the problem you have.
MODIFY MAS = BAD IDEA...end of discussion
Update 09/15/99. I am glad that I chose to remove the lower chamber in a manner that allowed me to put it back in, because after over a month of screwing around with fuel pressure, the AFC, and idle control, I finally decided to put the lower chamber back in to see what would happen.
I had been having low speed drivability problems. When the rpms would fall from 4k or above, the ISC was not able to catch it, and the car would die over half the time. I set the base idle to 1100 rpm, and it didn't die anymore, but it did have a bit of a surging problem, but not too serious. I drove it like this for many weeks. It also was very "jerky" at low speeds and throttle positions less than 10%, the car would start bucking, requiring continuous clutch finesse at parking lot speeds.
I decided the 1100 rpm idle and +/- 500 rpm surging was just not my "style" so I messed around with everything trying to make it better. I put the lower chamber back in and lowered the idle to 750 and blammo everything worked like a "stock" car.
So my finally diagnosis is that with the lower chamber removed, at low airflow rates the air would easily flow through the "hole" and hardly any of it would go through the MAF counter, as a result, I had all of the problems above. At high airflow rates, a great deal of air would get sucked through the MAF counter, even though it was more restrictive, and it could be tuned. Many people design some kind of "flapper" so that at low airflow rates the air is forced through the MAF counter and at high airflow rates, the flap opens and air can go through both chambers. I haven't explored this idea yet. I think I am just going to leave the lower chamber in there and start looking for a 2G MAF.
Randy Nuckels
the problem with that statement is I DID NOT MESS THE MAF UP there is no way i messed it up- im not a retard- your not listening - it is a bad idea on some cars (underline some) just look at the post above- your opinion is that every fast dsm out there has to have the maf hacked- which is a bunch of sshhiitt- because i know it is possible to have a 12 sec dsm that has the stock maf - or a 2g maf - which is also stock- before you go running your mouth check the facts partner.........
and in no way is this thread about maf=bad idea- look at the freakin original post!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i was just asking if it could be a potential porb. and it turns out that it can
ok first off im not trying to come down on you for helping - i thank you for helping BUT BUT what have you helped with again- you are claiming i said something that i have not - i never ever claimed that modifying the maf was a bad idea the original post was about IF it could pose a prob. maybe you sould of been the first one to post and then we would not have 55 or some posts
this is incase you didn't read it the first time
well answer a question for me- im not thinking it is the maf from your post- i give you props for your long experience with it - could taking the restrictor out of the bcs open the wastegate sooner and im loosing boost that way - that is my only explaination for my car- if this sounds right let me know - if not than it has to be the maf
because if it is im going to get a manual boost controller and say ffuucckk it - either way im getting a mbc soon anyway
you pin pointed it exactly the car has some serious pull in 1st then 2nd a little then none in 3rd 4th and 5th gear it completly falls on it's face
