Missing Ignition Lock Cylinder
CrimsonPaint
Jun 22, 2024
Denver, Colorado
Hello! I recently purchased a 1992 Mitsubishi Eclipse GSX and have been working on repairing it. One problem I have run into is that the car did not come with an ignition lock cylinder. I have tried searching to find one online and I have not been able to find any. Is there any other ignition lock cylinders from other cars I can use or anything else I can do?
Thanks!
Should be MB590873, eBay shows a new old stock one for sale. Alternatively you can see if jnz can get one in.
Is it an automatic or a manual? Mitsubishi lists different part numbers for each
Manual - MB590873
Auto - MB590990
I did a little searching and it doesn't appear that any other Mitsubishi cars used the same ignition lock cylinder. Your best bet is to put a want ad in the classifieds here or save a search on eBay. I've seen plenty of them over the years, another one is bound to pop up.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
