1G Multiple electrical issues. Ignition Switch?
Murderedoutdsm
37
Nov 2, 2011
Boyds, Maryland
Hello All. I've been having a variety of electrical issues. I think I may have finally found the culprit, but wanted some input before ordering and installing a new ignition switch.
Issues: Hazards do not work. Blinkers work but do not indicate on the gauge cluster. Fuel level, engine temp, and oil pressure gauge do not work on gauge cluster. Rough starts.
I replaced the following parts with no change: Gauge cluster, fuel level sending unit, temp sensor, oil pressure sender, Coolant temp sensor, hazard switch, and the blinker/hazard box which makes the clicking noise (behind radio).
I was looking at the electrical diagrams in my Haynes Manual and all of the accessories I am having issues with had the ignition switch in their diagram. I searched "Ignition Switch" in the forums and could not find a similar situation as mine, so I thought I'd ask.
Do you guys think replacing my ignition switch will fix these issues? Your input is appreciated!
Ok will do. Thank you for your input!
I used a test light and all the fuses were good. I still need to get a multimeter to test the voltage, which I will do tomorrow morning. I checked all the grounds in the engine bay and they were good too. Are there any grounds under the dash that could be bad?
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
