Miss or stutter only at idle.
wags122
81
6
Jan 19, 2005
Snohomish Co., Washington
Recently installed my 6 bolt swap in to my gsx and have been having a problem with it at idle. it seems to miss or stutter only at idle and is intermittent, it drives fine, revs fine. Car has no idle surge, holds steady at 750 rpms. Plug wires have been swapped, non 95-96 cas checked in link, no cel, wb reads 14.6-14.8 at idle. Searched and all idle threads seem to have stalling or idle surging issues also so i'm quite stumped? Any help is much appreciated thanks.
Sounds like a ecu problem coil, pack, or wiring, check your injector wires, you could have a bad injector, rule those out, you never know it could be something is wrong even though you have checked it so check everthing more than once. Could be the cas too.
