Misfiring...
1992EagleTalon
Apr 29, 2006
LaCrosse, Wisconsin
My car missfires at lower RPM's but is fine at higher RPM's. I just replaced the plugs like 1.5 months ago so that shouldn't be the problem... also my car seems to jerk hard at lower speeds (10-20 mph) in first and second gear. my car also surges because what i believe to be the aftermarket cruise control that was installed in the car before i purchased it... (not sure, but i was thinking since cruise control just vacuum pressure then that could be where the leak is coming from...) any help on this issue would be nice!
:talon: (2.0 N/t 4g63)
I would definately check for vacuum leaks first then check things like fuel pressure at lower rpm and check your o2 sensor.
thanks, but i could it be my fuel pump too? Cause it seems after i let my car sit for like 2 hours without driving it it takes a while to start it up. I do live in Wisconsin and it's winter time but even when i use my block heater it still doesnt start up very well. Pretty much just the same as without using it in the first place. But yea any help would be great thanks
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
