Mighty Max Auto to manual
Mighty4g63
Dec 20, 2021
Harrisonburg, Virginia
Hi, I'm working on my mighty max i swap a 4g63 with automatic wiring harness what cable i need from auto transmission or i no need any from auto transmission?
No cables except for the mechanical shifter for the transmission to put it into Park, Reverse, Neutral and Drive. The gears are controlled by shift solenoids in the valve body. All that "requires" is 2 SPST toggle switches to control the gears, or you can install a stand alone TCU, such as ForcedFour.com has for sale.
It is all pretty simple. :thumb:
what I'm talking about is that if I connect the engine cable I can remove all the wires that go to the transmission because the pick up truck is manual I won't need them
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
