FRslimmyjim
- 144
- 2
- Dec 28, 2010
warwick,
New York
Hey guys, so I am building a megasquirt 3 with the expansion board. I am about to solder in the capacitors. But it says that if I am using a coil trigger input to do certain steps and if I am not using the coil trigger input (fuel only) that I should do certain things. It says the using the coil trigger input is rare. But then it says that you CANNOT trigger from coil negative if you are trying to run ignition or sequential fuel. I don't know what this is asking so I don't want to go any further without knowing. I am so lost haha. Can anyone explain this to me? I want to run fuel control for a little while till i get more mods on my car and then I want to run ignition with the megasquirt. Thanks for all the support.
