Megan racing turbo manifold
98gsxtuner
455
Jul 30, 2008
bloomfield, Nebraska
No it will not fit your turbo, this manifold is T-3 flanged where your 16G is mitsu flanged.
Personally I would not buy that manifold, just use a ported 2G manifold there proven for 500hp. If your dead set on a tubular manifold be looking to spend around $500+ on a quality manifold that wont crack. Are turbo cars see alot more heat that an N/A car, which is why N/A's can usually get away with the ebay headers.
Ebay tubular manifolds = junk
It probably has more to do with the weight of the turbo putting stress on the mani
I question your statment for the simple reason that the o2 housing and downpipe are supporting a good portion of the turbo and then my intercooler is holding up a good portion of it aswell. I had to take the downpipe off to drop the turbo a little bit to get my manifold off.
My downpipe doesn't hold much of the weight at all. If I take the 4 turbo-mani bolts off first, the turbo will drop 2", at least on my setup.
