Megan Racing coilovers setup before install...
ZLODEY
85
Sep 9, 2006
Vilnius, Europe
a) If someone could make an advice on how to setup Megan Racing coilovers before installing them? Ideal situation would be to know what height parameters should I use to get 1.3” (~35mm) drop for the front and rear :confused:
b) Also... We have 62.180.014F/006R which means 180mm spring height on the front and rear coilovers. My question would be should it have some preload (pressed a bit) of ~5-10mm or should I leave it as it is? :rolleyes:
Thanks for input! :) But then, maybe it's a good idea not to "adjust higher", but to get a higher spring which will have more space to move? Same or maybe even stiffer 8kg as was suggested before... :)
BTW who is selling those springs separately :confused:
The valving is bad, you can't fix it by improperly springing your car either. Spring rate should not be dictated by a bad valving. Youd be chasing your tail.
Guys, where can I get only MR springs with different spring-rate? Like 62.200.008 for example?
BTW how big is difference in weight didstribution between GSX and EVO which uses 62.180.012F and 62.200.010R :confused:
OK, I see it now... but still thinking about buying 62.200.010 (EVO setup) for rear coils
