MBC questions about vacuum line hookup
GSTurbo1
610
May 2, 2012
Pickens, SC, South Carolina
Ok I found out why my MBC is not working (only getting 8-10lbs. boost). i'm pretty sure I hooked it up wrong. So I have a vacuum line coming off the turbo, goes to a T fitting (no check valve), One end goes to the BOV and one goes to the boost controller then to WG actuator. Could this be why it's not working. the BOV is a blitz
yep def got it hooked up wrong. What does my bov vacuum line need to be run to? It is mounted on a flange that is welded onto my turbo piping. Have no clue what to run the vacuum on the top into.
I want to run the turbo compressor vacuum straight to the BC then to WG actuator.
let me know so I can :rocks::hellyeah:
i would imagine the MBC goes on the line connecting the compressor housing to WG..
Well, My vaccume setup is :Turbo>Vaccume T>Wastegate>Boost controller. IMO The BOV should go somewhere else on the back manifold. I believe there are 3 sources on the back of the manifold. Hope that helps a little.
  • For sale NEW Magnus Forged Transfercase gears PENDING
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
