vacuum line questiion
long84les
32
Aug 4, 2007
norfolk, Virginia
if i hook up the vacuum line from the waste gate to the compresser and not have a boost controller where do i hook up the vacuum line for the blow off valve. also.. if i have a 10 psi spring in the waste gate, does the bov have to have a 10 psi spring also. hows that work?
The bov vacuum line normally runs to a nipple on the intake manifold.
I see you're an N/T so I don't know if you have added a turbo kit or have another car. The way the bov works is by determining the difference between boost and vacuum. While you're on it and it's seeing boost, it doesn't do anything. Once you get off the throttle and it sees vacuum, it opens up to release the air. The bov to intake vacuum line should not have anything teed into it either. The wastegate spring has nothing to do with the bov.
If you have any unused nipples on the back of your intake manifold you can use one of those. If they are all being used already as mine were, you will need to tee off of one of the vacuum lines.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
