a frenchie
- 0
- Apr 26, 2006
kansas city,
Kansas
ok heres the deal, yesterday i recieved this specific mbc from dynasty auto. http://cgi.ebay.com/ebaymotors/B-TU...0QQihZ019QQcategoryZ33742QQrdZ1QQcmdZViewItem
so i hooked it up as shown inthe pictures with the bottom line running to the waste gate actuator, and the top line running to the t fitting that came with the kit.
after installing everything i set the mbc to its lowest setting and took it on a run. i hit 8 psi according to my boost gauge. i pulled over, turned it up, ran again and hit the same. so i turned it all the way up. yet again i hit 8 psi. there has to be something rong here because stock i was running 12 psi. so i switched the hoses around on the mbc and got the same result. i double and triple check my installation and it is correct. ### is goin on??
thanx jon
thanx jon
Did you even read the thread at all? Don't tap the BOV line!!!!! Yes, I'm saying Hallman is wrong on this particular subject.
