** mbc problem***
TSI_TILLIDIE
Banned Member
31
Dec 23, 2010
chicago, Illinois
SO ALL DAY I HAVE BEEN ADJUSTING MY BOOST CONTROLLER I MADE AND IT WONT GO PAST 9 PSI NOW I READ THREW ALL THE FORUMS ABOUT THIS AND NONE FIXED MY PROBLEM BUT I THINK MAYBE IT MIGHT BE THAT THE BOOST SOLENOID ELECTRIC WIRES ARE PLUGGED IN BUT NO VACUUM LINES. I DONT THINK ITS THE FPR THOUGH ANY HELP
link to the mbc:http://www.c-speedracing.com/howto/mbc/mbc.php
The boost solenoid can't affect squat once its lines are disconnected. You need to just walk through your mbc and its install. Spring could be the problem if everything else checks out.
Also, find a keyboard with a working caps lock key.
Sorry im bad at typing and do i wannt a lot of air to pass threw the mbc
If it isnt the mbc what other ideas do u think it could be?
I THINK YOU PROBABLY HAVE IT HOOKED UP WRONG. OR YOU MADE IT WRONG.
DID YOU READ SOME OF THE TROUBLE SHOOTING STUFF ON THERE?
-YOU MIGHT NEED TO STRETCH THE SPRING SO IT APPLIES MORE PRESSURE TO THE BALL.
Oh... and please don't use all caps anymore. The rest of us have no problems reading a mix of upper and lower case.
EDIT: And don't make a new thread when you don't get the answer you want fast enough.
i didnt understand tommorow im going to make the spring tighter.
Don't make multiple threads on the same subject. Either someone knows the answer to your question and answers it when they can, or that person isn't online at the moment and will get to it the next day (or whenever).
+1 good luck with it
I MADE MY OWN PART AND NOW MY SHIT DON'T WORK. WHAT DO I DO?
....buy the same part from someone that builds them everyday and knows what they're doing, because obviously you didn't do something right.
Do you honestly expect us to be able to lend you advice to repair something that YOU built? None of us could possibly own the exact same part, so basing a thread on it is pretty pointless. You could have built it out of soda cans for all we know.
