mbc on external wastgate
brandons 95
95
Jan 13, 2006
deltona, Florida
If you go with an external wastgate where do you hooke the hose from your mbc that goes to the actuator if you remove the acuator
External wastegates have two nipples on it for hookups. When using a MBC just hook up the bottom nipple to the MBC. The top nipple is mainly used for EBCs to keep the wastegate fully closed until needed.
I dont have no experience installing one before so I really can't say. But from what your saying the best place would be off the bottom one nipple right. Since the top one is mainly used for EBCs, and he has a mbc. Or does is make no difference.
Good luck with that and have fun!! When it comes time to install one on your car, you'll know what to do!!:thumb:
