2G MAP sensor?
Your first gen engine does not have this mounted on your intake manifold, either you can plumb it on to the top of the manifold with some drilling and welding, or you can connect it to the break booster vac line. This is the biggest line out of the back of the manifold. You'll have to lengthen your wires but it will work.
It's not a MAP sensor, its the MDP sensor and it's for emissions. Just hook a vacuum line to it if you don't want to throw a CEL.
