MAP sensor voltage/Zeitronix
WillyC
62
Feb 25, 2004
Huntington, West Virginia
I got the Zeitronix wideband kit with LCD screen. It has an optional input to read boost. The thing is you have to buy their MAP sensor. If anyone knows what the voltage outputs are to the symbol than it would be possible to use a cheaper sensor. Anyone with any info on this please respond.
Most sensors are in the 0-5v range. Go to www.digikey.com Order the MPX4250AP-ND sensor, will read up to 2.5 BAR of pressure, It cost $18 each. I recommend ordering two of them. They're a sensetive component to engine heat, so I also recommend going to Radio Shack and getting one of those small boxes to mount it to.
Thanx for the help bro. So I was thinking about how I could determine the boost it reads at particular voltages. If I used a multimeter and found out specific voltages for specific levels of pressure and vacuum than how do I go about altering the signal coming from the generic MAP sensor into my Zeitronix control unit? I know that voltage=current x resistance so would I just wire in the appropriate sized resistor?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
