1G manual trans reverse problem??
92tsi4x4
51
8
Sep 1, 2013
Alliance, Ohio
Hello all,
I have recently swapped in a used 23spline manual transmission and matching transfer case. When I had the car up on jack stands after installed the transmission and transfer case I ran it thru all the gears and they all worked fine. I had some trouble getting it into reverse it popped out but I held it in and had reverse. At the time the clutch still needing some bleeding so at that point in time I blamed it on the clutch needing bled. Finally I got the car buttoned up and clutch bled and pulled out of the garage went to back up and now I have no reverse. And the strange problem is when I put the shifter over and down into reverse and let the clutch out the car creeps forward.... Any input?
