Manifold
How much are you looking to spend? That should be your first question. Then when you figure that out, these manifolds suggested above will most likely be one that you choose.
Couldn't say it better myself.
It terms of worst to best:
1. 2g manifold
2. 2g ported manifold
3. Evo3 manifold
4. FP Race manifold
Further up the list you go, so does the dollar amount.
Thanks for the info guys. I am in the same market: just discovered a separation crack in my crap tubular china header.
I have been shopping around for different vendors offering the FP cast manifold, and I will most likely spring for it. Where would you recommend purchasing to get ceramic coating and an EGT bung tapped at the same time? I am looking for the simplest/quickest solution, hopefully done by the vendor. All suggestions are appreciated:
And thanks again to OP for kicking off the discussion.
Matt
