Major DSM Turbo Problems
90eclipseDSM
Jun 19, 2007
Concord, California
Hi, recently I just installed a stage 3 Clutch and a 11 lb flywheel.
I got the car running today, went for a drive for a few hours. In those few hours the car has that surging idle and when im driving it, the RPM gauges goes up and down like the idle surge. Also it mis fires a bit. Then a hour ago, driving home, the car throughs a CEL and wants to die, it hesitates and sounds like the turbo just fell and it is running open header. I start the car again and drive it for 1 minute trieng to go home, then it does it again. I start it again and it drives fine home. Now I look on the bottom of the motor, it looks like it had an oil leak, and there wasnt much oil.
Long story short: Car Hesitates, Mis Fires, Stalls, Idle Surges during idle and when im driving and there seems to have an Oil leak on the oil return line. Please help if you can. Ill try to be more descriptive. Thanks
Did you make sure to connect all the electrical connections you removed when installing the clutch /flywheel (MAF, TPS, IAC, cooling fan(s)..etc). Do you have a means to check the CEL that you saw?
Where exactly is the oil leak eminating from? Was it there prior?
Definitely check the turbo wheel for excessive lateral /longitudal freeplay (remove intake). If it does and or if there is alot of oil residue, it may be hurt. Note that low oil, even for a small amount of time can kill a turbo quickly :dsm:
Ya, everything is connected when I installed the clutch and flywheel. Last time I checked the turbo wheel, it didnt feel loose or anything and this was when I was installing my clutch and flywheel. I think the oil is leaking from around the oil return line where it connects to the oil pan, because it is pretty oily around there. The CEL came on then the car died, I restarted car then it came on again, then i started it again and it went away. Today I was driving it again and when I went into full boost the RPM gauge went from 6k to 3k then went back to 6k. Also car mis fires over 6k
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
