maft settings for stock injectors on a galant vr4
tim18t
Jan 17, 2006
hoffman estates, Illinois
i have a keydiver chip already compensating for my larger injectors so i need to set up the maft as if it was seeing stock injectors (from what ive read).
what would the settings then be on the maft dials?
It depends on which version you have. I think 1.3 stock base setting is 0 and the 2.XX stock setting is 2. full throttle speed has a forum with the instructions. You should check there to verify.
    • Sdcryan1
