MAFT/SAFC Tuning 850cc
Dave_Hash
170
Oct 18, 2003
Stratford,
Are you able to tune 850cc injectors with a maf-t set to the default 850cc setup and a SAFC to do fine tuning? If not what is the biggest injectors that I could use with the maf-t and SAFC together?
I want to know if I can tune the 850cc with the maft and the safc together
Let's just put it this way. Would you be able to tune? yes you would. Would it be a good tune? No. Would you be getting the most out of your setup? No.
Would you really wanna take the risk of running too rich or too lean and possibly causing engine damage? Only you can answer that.
Thanks for the replys.
The only reason that I was even considering using 850cc injectors was because someone that thinks they know everything about DSMs said that I must use them with the t3/t04e or I would hit fuel cut. I felt that the 650cc would be fine for now and that is what I wanted to use. I plan on getting the 650cc until I get my 6 bolt built and DSMLink in.
Yah i also have to agree with most of the people in this post. I am running 680cc on the safc II and maft Gen 1 3" gm. I am having quite a time getting a good tune with even these size of injectors. I'm considering upgrading to the Gen 2 MAFT and getting a wideband and test out the wideband tracking on the new MAFT.
Hitting fuel cut has nothing to do with what injectors you're using.
T3/T4 doesn't really say anything about a turbo so we can't really answer you there on your injector requirements.
