Maf-t tuning help idle surge
gnatali7
Jan 17, 2010
chicago, Illinois
Hi Guys need help I have 91 tsi 6 bolt - eagle rods - wiseco pistons - arp head studs - cometic head gasket - MISHIMOTO 2 1/2" radiator - 30R turbo - 2 1/2" ICP - front mount greedy IC - Greedy BOV - AEM FPR - 750cc injector clinic injectors - MAF-Translator 2.01 - 3 1/2" GM MAF - APEXi afc - 63mm Thottle Body - gm maf is after BOV right before the Tb bend --- I have the maf-t set AUX 2 Base 0 Idle 5 - my wide band reads between 14.5 to 14.9 at 1050 rpms which is perfect Timing advance is around 9 degrees - After idling like that for 10 sec idle surge begins rpms go up to about 1450 then drop off back down to 1000 rpms stays rich for a couple of seconds at 12.6 to 13.0 then it evens out back to 14.5 to 14.9 for another ten seconds and idle surges again ----- Is there anyway to get rid of the idle surge ---- originally i had the maft set aux 2 base 2 for my injectors but it would idle lean or rich so i set it smaller size injector to richen up the mixture
my fuel pressure is 36 psi
crank angle sensor is all the way retarded to the max
HELP PLEASE what am I doing wrong how can i get rid this idle surge ???
Set it to Aux 0 Base 2 and set all the other dials to 0. Put the second little switch down in the bottom left corner ( MAF selection switches) into the ON position with ALL the others ( 1, 3, 4 ) in the OFF position. After you so that, see how the cars is running once fully warmed up and then tune it out with the AFC
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
