yeti-gvr4
- 422
- 2
- Dec 23, 2010
san diego,
California
What is the WB switch point supposed to be at. Cause mines at 2.49 volts
On the log it doesent show a accurate reading of the wideband at all. It shows the wideband but it old goes between 7.8 and 10.2
Is it supposed to say delay for 15 seconds.
Just trying figure this out cause I'm locked in open loop
Should also throw in that I thought all you had to do was click on 2g maf to be able to runa 2g maf on a gvr4 is it true I have to do some math and adjust the maf compensation sliders?(I'm ready to do the maf comp just wanna make sure I HAVE to.)
I didn't feel any difference after swapping the 2gmaf and there was no CEL or nothing.
Its probly bad I'm running around in open loop correct? That's when there's no feed back right its just reads what the ecu BELIEVES. It should be?
Thanks
Colin
Thanks
Colin
